Shows the DHCP relay agent remote ID.
If a remote ID has not been configured, or it has been unconfigured, the default remote ID is the switch's MAC address. However, this default remote ID does not appear in this command.
This command shows the remote ID set by the configure ip-security dhcp-snooping information remote-id [system-name |remote-id_info] command. If the remote ID has never been configured, or it has been unconfigured (unconfigure ip-security dhcp-snooping information remote-id), the default remote ID is the switch's MAC address, which does not appear in the output of this command.
The following command shows the DHCP remote ID:
# show ip-security dhcp-snooping information-option remote-id Switch Remote-ID information string ------ ----------------------------- model name mydhcp
The following command shows that the DHCP remote ID has never been configured, or that it was unconfigured, and that the default (switch MAC address) is being used, but this default remote ID does not appear in the output of the command:
Note: If neither System Name nor the Customized remote id is configured
the default will be the Switch MAC address, that will not be shown
